AMD Ryzen 3 1300X & 1200 Performance Review
Share:
7-Zip
At face value, 7-Zip is a simple compression/decompresion tool like popular applications like WinZip and WinRAR but it also has numerous additional functions that can allow encryption, decryption and other options. For this test, we use the standard built-in benchmark which focuses on raw multi-threaded throughput.
Adobe Premier Pro CC
Adobe Premier Pro CC is one of the most recognizable video editing programs on the market today as it is used by videography professionals and YouTubers alike. In this test we take elements of a 60-second 4K video file and render them out into a cohesive MP4 video via Adobe’s Media Encoder. Note that GPU acceleration is turned on.
7 Zip shows the Ryzen 3 processors exactly where we would expect them ahead of the 7300 and 7100.
Meanwhile Adobe Premier really likes these two Ryzen 3 processors since they score very well in our 4K media encoder video test. As a matter of fact, with a little bit of overclocking the 1300X shouldn’t have any problem achieving results that are pretty close to the Ryzen 5 1400!
