AMD Ryzen Threadripper 1920X & 1950X Review
Editor-in-Chief
CineBench R15 64-bit
The latest benchmark from MAXON, Cinebench R15 makes use of all your system’s processing power to render a photorealistic 3D scene using various different algorithms to stress all available processor cores. The test scene contains approximately 2,000 objects containing more than 300,000 total polygons and uses sharp and blurred reflections, area lights and shadows, procedural shaders, antialiasing, and much more. This particular benchmarking can measure systems with up to 64 processor threads. The result is given in points (pts). The higher the number, the faster your processor.
PCMark 8
PCMark 8 is the latest iteration of Futuremark’s system benchmark franchise. It generates an overall score based upon system performance with all components being stressed in one way or another. The result is posted as a generalized score. In this case, we didn’t use the Accelerated benchmark but rather just used the standard Computational results which cut out OpenCL from the equation.
WPrime
wPrime is a leading multithreaded benchmark for x86 processors that tests your processor performance by calculating square roots with a recursive call of Newton’s method for estimating functions, with f(x)=x2-k, where k is the number we’re squaring, until Sgn(f(x)/f'(x)) does not equal that of the previous iteration, starting with an estimation of k/2. It then uses an iterative calling of the estimation method a set amount of times to increase the accuracy of the results. It then confirms that n(k)2=k to ensure the calculation was correct. It repeats this for all numbers from 1 to the requested maximum. This is a highly multi-threaded workload. Below are the scores for the 1024M benchmark.
In our synthetic benchmarks we see there being a bit of positive and negative for Threadripper. In Cinebench multi core the 1950X and 1920X outclass the i9 7900X in a big way but when dealing with the mixed workloads of PCMark, the situation changes quite quickly with both being middle of the pack performers. Then WPrime comes around and the Threadripper processors are right back on top with amazing results.
Latest Reviews
