MSI B350 Tomahawk AM4 Motherboard Review
Share:
Test Setups & Methodology
For this review, we are going to be testing the performance of the MSI B350 Tomahawk four configurations: default settings @ DDR4-2133, default settings @ DDR4-3200, automatic overclocking settings, and manual overclock settings. The components and software are the same across all five configurations, and aside from manually selecting the frequencies, timings, and voltages in the manual overclock configuration, every option in the BIOS was at its default setting.
AMD Ryzen AM4 Test Setup
For all of the benchmarks, appropriate lengths are taken to ensure an equal comparison through methodical setup, installation, and testing. The following outlines our testing methodology:
A) Windows is installed using a full format.
B) Chipset drivers and accessory hardware drivers (audio, network, GPU) are installed.
C) To ensure consistent results, a few tweaks are applied to Windows 10 Pro and the NVIDIA control panel:
- UAC – Disabled
- Indexing – Disabled
- Superfetch – Disabled
- System Protection/Restore – Disabled
- Problem & Error Reporting – Disabled
- Remote Desktop/Assistance – Disabled
- Windows Security Center Alerts – Disabled
- Windows Defender – Disabled
- Screensaver – Disabled
- Power Plan – High Performance
- V-Sync – Off
D) All available Windows updates are then installed.
E) All programs are installed and then updated, followed by a defragment.
F) Benchmarks are each run three to ten times, and unless otherwise stated the results are then averaged.
Here is a full list of the applications that we utilized in our benchmarking suite:
- 3DMark Vantage Professional Edition v1.1.3
- 3DMark11 Professional Edition v1.0.132.0
- 3DMark 2013 Professional Edition v2.3.3693
- AIDA64 Engineer Edition v5.90.4242 Beta
- Cinebench R15 64-bit
- FAHBench 1.2.0
- Final Fantasy XIV: Heavensward Benchmark
- Grand Theft Auto V
- HEVC Decode Benchmark (Cobra) v1.61
- LuxMark v3.1
- Middle-earth: Shadow of Mordor
- PCMark 8 v2.7.613
- SuperPi Mod v1.9 WP
- Valve Particle Simulation Benchmark v1.0.0.0
- WinRAR x64 5.50
- wPRIME version v2.10
- X3: Terran Conflict Demo v1.0
That is about all you need to know methodology wise, so let’s get to the good stuff!
