Innovation Cooling 7 Carat Diamond TIM Test results thread (goes live April 1, 2009)
THE FORMAT IS AS FOLLOWS (ALL TEMPS IN C):
OPTIONAL INFO: PROCESSOR, VOLTS/CLOCKS, HEATSINK/COOLING USED, ETC.
Pre-IC7
Compound:
Abient Temp:
Idle Temp:
Load Temp:
IC7
Ambient Temp:
Idle Temp:
Load Temp:
If you have any problems or need support, please feel free to post here for now. The goal is to get all this info posted in the results thread which I will create shortly and ask Gav to sticky also. Remember, proper application and good even heatsink pressure (goal should be minimum of 50psi or more) are crucial for peak performance. Too much or too little compound will impact your results so please do visit the Innovation Cooling website for Application Instructions with images and explanations. There is a direct link in the second post in this thread. For those with direct touch heatpipe coolers, you might want to try wetting the contact surface of the cooler with a tiny amount of IC7 to fill any small voids before proceeding with the normal application method.
:canadianwave:
PLEASE READ THOROUGHLY BEFORE TESTING/POSTING YOUR IC7 RESULTS!!!
:canadianwave::canadianwave::canadianwave:
RESULTS THREAD IS NOW LIVE!!!
PLEASE ONLY POST WITH RESULTS WHEN YOU HAVE FULL RESULTS, OTHERWISE YOUR POST MAY NOT BE SEEN BY ALL IF YOU RESERVE THE POST FOR LATER RESULTS WITH IC7. PEOPLE TEND TO GO TO THE NEWEST POST, SO IF YOU WANT IT TO BE SEEN BY ALL, POST YOUR RESULTS ONCE YOU HAVE THEM ALL. ALL OTHER DISCUSSION/SUPPORT POSTS, GO RIGHT AHEAD!!
PLEASE BE SURE TO BENCHMARK YOUR CPU TEMPS WITH YOUR CURRENT TIM AND RECORD YOUR RESULTS BEFORE USING IC7 FOR TESTING. WE NEED BEFORE AND AFTER PLEASE! :thumb:
ALSO, PLEASE MAKE SURE YOU DON'T CHANGE ANY VARIABLE OTHER THAN THE THERMAL COMPOUND USED FOR BEFORE/AFTER (I.E. SAME VOLTS/CLOCKS, COOLER, AND OTHER HARDWARE)
APPLICATION METHOD
HOW TO POST RESULTS
APPLICATION METHOD
For all those participating in the IC7 giveaway, please follow this link to the Innovation Cooling website:
Innovation Cooling
Proper application is the key to this product. The nature and consistency of this product is likely quite different from what most of you are used to in a Thermal Compound. Don't use traditional methods of applying the TIM like razor blades, lines, x's, etc. Through extensive testing, the best application method has been determined to be a pea sized amount directly in the center of the CPU. The TIM should be adequately spread via the downforce of the CPU cooler (a sufficient amount of downforce will provide best results; minimum 50psi of downforce should be the goal for optimum results. please see the Innovation Cooling website for more info). Also, for coolers/surfaces that have many peaks and valleys, it may be beneficial to wet the surface(s) with a small amount of IC7 to initially fill the voids in the mounting surfaces...then proceed with recommended application as usual. Please click on the link below for application methodology and shoot me a PM if you have any questions.
Keep in mind, IC7 has been formulated with the specific goals of providing superb thermal conductivity with short set times, but also for long term stability and performance without pump/bakeout through extended thermal cycling or usage. This stuff is very stable over long periods of time.
APPLICATION INSTRUCTIONS
Please do feel free to navigate through the whole Innovation Cooling website as there is tonnes of information on there that might prove beneficial.
Innovation Cooling
HOW TO POST RESULTS
Pre-IC7
Compound:
Abient Temp:
Idle Temp:
Load Temp:
IC7
Ambient Temp:
Idle Temp:
Load Temp:
:canadianwave:
