Total panic, motherboard don't start.
Mavvens
Montréal
Alright. I have a MSI 790fx-gd70
I have a power supply tester, so a couple of things are eleminated.
I was building and testing my watercooling setup, and I played game and everything seem normal. So it booted.
I think I rosted my motherboard. The system just flash electricity and that's it.
So the motherboard illuminate for a few millisecond and afther nothing, no electricity at all.
I use Feser one not conductive coolant by the way.
But the think that I don't understand is that I got a power button on the motherboard and that one is illuminated. So electricity go to it, but the motherboard doesn't work at all.
I tried to remoove the battery, nothing again...
I think it might come to a dead end...
:sad:
enaberif
Calgahree, AB
:sad:
All coolant is conductive.
Some are less than others.
Mavvens
Montréal
re
I suspect the northbridge one.
I will try to RMA see what's going on.
I think that's the only option for me!
gingerbee
Orillia, Ontario
umm did you spill anything?(wondering why you think it's the fluid). cause it just sounds like something shorting out your board try a fully clear cmos button on the back panel or on the board
