somecanadianguy
Anyone having problems setting affinity/priority check out WinAFC:
WinAFC | Get WinAFC at SourceForge.net
(Don't click the 'Download Now' button... click 'View all files' and make sure to get the proper version for your OS)
Download and extract the .zip archive.
Open the file 'affinityinput.txt' and add these lines to the 'Application Profile Lines' section (at the bottom):
This sets affinity of GPU client to all cores and sets priority to high.
You can also set CPU affinity/priority for VMware folding:
Note:
The above code is for Intel i7 systems with HT on.
Here are the values for other processors...
Note 2:
WinAFC needs to be 'Run as Administrator' to work properly.
Important:
Test mode is used to check your syntax and is enabled by default.
When enabled any changes you make will have no effect.
To shut off test mode set to 0, or comment the line with # :
There's lots more info on how to use WinAFC: WinAFC
Hope someone finds this helpful.
(Tested on Vista Home Premium 64bit and Windows 7 Ultimate 64bit.)
Code:
*\FahCore_11.exe := PAIR0+PAIR1+PAIR2+PAIR3 [priority=High]
*\FahCore_14.exe := PAIR0+PAIR1+PAIR2+PAIR3 [priority=High]
Code:
*\vmware-vmx.exe := PAIR0+PAIR1+PAIR2+PAIR3 [priority=Low]
Note:
Code:
Intel & AMD Dual Core: CPU0, CPU1 or PAIR0
Intel QuadCore: CPU0, CPU1, CPU2, CPU3 or PAIR0, PAIR1
AMD QuadCore: CPU0, CPU1, CPU2, CPU3 or QUAD0
Intel Core i7 (HT on): CPU0+CPU1+CPU2+CPU3+CPU4+CPU5+CPU6+CPU7 or PAIR0+PAIR1+PAIR2+PAIR3
Intel Core i7 (HT off): QUAD0
Note 2:
Important:
Code:
# WinAFC Input File
# Lines that start with a '#' and empty lines are ignored.
# Configuration lines include global flag setting lines, and application profile
# lines. These lines can be interleaved in any order. However, the order in which
# you specify the various application profiles matters if a process could be
# matched by multiple application profiles.
# To run AffinityChanger in TestMode (no affinity settings are modified),
# uncomment the line below and specify a value different than zero. To disable
# test mode, set the value to 0 or comment the line below.
# It is recommended that you try the input file in test mode first, after you
# make changes, especially if you are unfamiliar with the syntax.
[B]TestMode = 0[/B]
