heres my upgraded rig
specs:
q9550 @ 3.8 ghz
4x1gb ddr3 1066 ocz @ 1333
XFX 790i Ultra
2 x gtx 260 in SLI one evga non core 216. second asus and it IS a core 216. seem to be running fine so far
xfi xtreme gamer sound
2 x seagate 32mb cache 1tb in raid0
sata2 LG dvd burner
enermax galaxy dXX 1050w psu
antec 1200 case
water cooling:
pa 120.2 mounted in the top
swiftech 240mm rad in back
2 x danger den acrylic reservoir's with 2x UV led drilled in back
2 x Laing DDC 3.25 -12V 18 Watt Version
2 x acrylic tops with rez built in
d-tek fuzion i think cpu block with quad core insert
1 x full cover block for gtx260 ( i cant find full cover for core 216 yet for my other card)
EK-MOSFET 790i Part 1 MOSFET Waterblock (Acetal)
EK-MOSFET 790i Part 2 MOSFET Waterblock (Acetal)
EK-SB VGA 790i Chipset Waterblock (Acetal)
viper jon 790i nb block
10 feet uv blue tubing
4 x acrylic L fittings for various strange angles
18 x bitspower g1/4 for 1/2 in tubing
4x compression fittings
Other:
replaced all fans but the 200mm fan in the top with 2500 rpm yate loon blue led fans 6 fans total + 200mm
lamptron 6 channel 45w per channel fan controller
2 x 12 inch uv cold cathode
2 x 4 inch uv cold cathode
2 x 4 inch uv bubble lights
custom made front panel for on off switch for uv lights
i get about 20k 3dmark06 not bad before i oc the GPU abit.
for the record: no i dont play guild wars lol. i ordered that on eBay for a friend and he still hasn't picked it up yet.
