I'm getting ~55K in ~2.2 days just on bigadv units with my i7 860 at 3.7. I suspect your CPU results would be around that. (That's without any GPU folding so your production will be higher.)Ok ...
What is a fair, realistic expectation of what a i7-920 or i7-950 at 3.5 Ghz,
or higher can do?
Add to that...
With -bigadv, an i7 at 3.5GHz or so with HT enabled should do about 22-25k PPD. If there are GPUs going in the same system, drop that by about 1000PPD for each one.Ok gents, I need some estimates here.
I already know what my Q6600's and GTX260/216/SE will do.
or higher can do?
Add to that roughly 16 to 17k PPD from a pair of GTX262/216 cards, please.
I have all the parts to built two of them on hand right now but I'd rather have
some ball park estimates of what to expect before turning the first screw.
Thanks,
Brad
Morning everyone.With -bigadv, an i7 at 3.5GHz or so with HT enabled should do about 22-25k PPD. If there are GPUs going in the same system, drop that by about 1000PPD for each one.
Also, since you came here asking for help, an apology for your outburst the last time you were here would be nice.
Thanks for the welcome back. That's about where I'm hoping to run. 4Ghz would be real nice, and I think the 950 should reach it pretty easily but I think thats stretching the 920 a little. Hopefully not, but I'll take what it gives me. Each box will have a pair of hot-rodded 260/216 cards in it, just because I already have them, but I await nvidia's new offerings as anxiously as everyone else. Wife is expecting, a daughter in fact, due in September. Not a whole lot of freedom time left!! Seriously, its like a dream come true. :biggrin:I'm getting ~55K in ~2.2 days just on bigadv units with my i7 860 at 3.7. I suspect your CPU results would be around that. (That's without any GPU folding so your production will be higher.)
Others with more experience and with 920/950's will be able to give you better estimates.
:funky.s. Good to see your old moniker back up on the boards here. I hope you and yours are well.
Thanks. Chances are, I'll need some of that luck when starting the overclock.I appreciate the apology. Good luck with the build.
