t_mo_t
:haha::haha:
Hey guys, finally came around watercool my rig
Specs:
i7 860 @ 3.8GHz
ASUS P7P55D-E PRO
CM Hyper 212 +
4x2GB Gskill ECO cl7 PC3-1600
eVGA GTX275 SC
CM HAF932
Ultra X4 850W
LG BluRay ROM
DVDRW
Used stuffs:
Swiftech MCR220
Swiftech 655 speed adjustable
The things I just bought from Daz:
EK-D5 X-TOP - Acetal G1/4 Rev.2
Feser One- Cooling Fluid - CLEAR /UV Blue
TFC - Stop Fitting w/ Slot Head (single unit)
Pre-cut pack 2m (6.5 ft) 1/2"ID Clear/UV Blue
K -Panel Through Mount, G1/4 Female with 1/2" Barb
TFC - High Flow C. Fitting G1/4" - 1/2"ID - 3/4"OD (single unit)
TFC - High Flow Fitting G1/4" - 1/2"ID - 3/4"OD - 45 Rotary
GELID Silent12 TC 750-1500RPM Thermal Sensor Speed Control Fan
GELID Silent12 PWM 750-1500RPM Power Management Speed Control
EK-Supreme HF Performance- Full Nickel - Universal CPU Block
EK-Multioption RES 150
TOTAL= BROKE:dots::dots::dots::dots:
So, I will start posting pictures when I get all the stuffs in my possession... should be real fast... updates tonight.. lol
**Edit 5/11/2010... Got the stuffs from Daz.. Thank so much Daz!!!!
For my fillport and bleeding (K -Panel Through Mount, G1/4 Female with 1/2" Barb with TFC - Stop Fitting w/ Slot Head)
EK Multioption 150 with the cyclone thingy..
Couple of rotaries (damn these are expensive.......:sad
Feser One Clear/UV blue.... shoulda gotten the uv blue instead.... to match my p7p55d-e pro..
X-TOP for my 655
4-Gelid fans; 2 PWM, 2 TC
Some fittings....
The heart of the beast!!!! i love this.. very shiny and high quality build!!!
****EDIT: 5/12/2010****
The pump with stock top.... fugly..... lol and i thought i needed to use some screwdriver to get it apart.... apparently just some twisting will do..
Before the sleeving with Vantec UV "red" lol
Poor man sleeving done
Woot... the top ... i love the material!! smooth and high build
Look at all those crap and the original O-ring is disgusting....:sad:
After cleaning the crap and installed the rear... is that where the replacement O-ring supposed to be?
Top is beautiful!!
Teflon tape in all the thread of the fittings (read it from some forum somewhere that it's to prevent further leaks?
Pump is ready! :clap:
Is this going to be overkill? lol
The cpu block with the rotaries!!
To prevent dust/contaminants while I m assembling other parts... lol
Specs:
i7 860 @ 3.8GHz
ASUS P7P55D-E PRO
CM Hyper 212 +
eVGA GTX275 SC
CM HAF932
Ultra X4 850W
LG BluRay ROM
DVDRW
Used stuffs:
Swiftech MCR220
X-TOP for my 655
Some fittings....
Top is beautiful!!
