mo' power
Great build! I'm looking forward to working on mine. It's good to see that cable management will be quite easy with this case.
I was also thinking about how to light up the dragon on the side panel. I read somewhere that if you can drill holes into the corners of the panel and insert led's, you may get the effect you're looking for. I don't mean drilling holes through the panel but into the edge of it. Then set the led's into the holes. I may try this on my build and connect the led's to one of the controls on my fan controller so I can dim them to the desired level.
