LCB001
Some people are going to be very very happy about this.
Get ready to upgrade your -bigadv client, Stanford is releasing the new A5 core soon that will be required for new -bigadv projects. The new core will have specific version snapshots that will include Linux at last.
Announcement by Pande group member Kasson;
Thread at the F@H forums; Folding Forum • View topic - upcoming core changes (bigadv will switch from A3 to A5)
Update: Kasson just made another post in response to a question about a 64 bit win client and added more info.
:canadianwave:
6.34 binaries now available for those that want to do the guinea-pig thing.
Posted By Kasson in the F@H thread;
Good Luck...
Just a heads-up: we are planning to migrate bigadv from running on Core A3 to running on Core A5 very shortly. Core A5 utilizes the same codebase as A3, but pegged to specific version snapshots. We have 64-bit Linux, Win32, and 64-bit OS/X versions of the core in testing; the initial release will likely be Win32 & Linux.
The new core will require a client upgrade; A5 will require version 6.34 or later. The Linux and Win32 versions of the 6.34 client will be released to the public very shortly. If you are running bigadv work units, please upgrade your clients. That will ease the transition as we start turning Core A5 bigadv projects on and turning Core A3 bigadv projects off.
Thanks and happy folding!
We don't currently have 64-bit A3 Windows cores in release; 64-bit versions of windows run the 32-bit version. This may change in the future, but the initial release of A5 will use the same model.
The bigadv changeover will be relatively rapid; we highly encourage donors who wish to run bigadv to upgrade their clients to 6.34 or later within the first few days of public release. We do not normally perform rapid switchovers for public-release clients, but bigadv is more of a "power user" configuration. After the switchover, pre-6.34 clients set to bigadv will roll over to normal A3 work units (and thus won't be spinning their wheels idly). We also have a number of non-bigadv A3 projects ready for public release that cannot go public until bigadv migrates for technical reasons.
:canadianwave:
The 6.34 binaries are now posted on the high-performance download page. We have a bit of cosmetic clean-up to do, but visit:
http://folding.stanford.edu/English/DownloadWinOther
to download the binaries. They can be dropped into a working FAH installation; it's always safest to update between work units, although testers have successfully performed this update mid-work-unit.
Good Luck...
