Addictedtokaos
Are the keyboard lights kicking on, like the numlock when you power it on? and if you are using a optical laser mouse do they get power?
Not sure why im always asked thay question, but naturally its connected. It's actually an 8pin on this board. All connections are made properly and fans are spinning.
Remove the chip from the new board, and check for bent pins in the socket.
ok your psu has only 1x4 wire then plug it in the other half, should have a psu that supprts 8 EATX12v
Don't mix PCI-e with EATX12v
just curious... did you push the ram into the socket... sooo hard? on my asus x58 sabertooth, i had to press them so hard...
Maybe its a video feed issue. If you are not getting any beeps, fans are all spinning up, and keyboard mouse are powering up, it just sounds like the video signal is not getting to your monitor.
Try another port on your video card, check the cables, make sure you monitor's input is set correctly. Try settings it again eventhough it may already be on the right settings.
