Alright so I recently installed a program called SteamJunction which allows you to have games on a different drive still accessible by your active steam client on another. Roughly 30 minutes after I had switched a game to my HDD and closed the program down I experienced a blue screen. I had my F@H client up and running as well as Steam installing a game while I was watching southpark. The video started to move really slow so I paused it and 5 seconds later the blue screen popped up. I had to go into the repair wizard and restore to a previous state before it would boot windows (I have windows 7 professional 64bit).
Now my HDD is not showing up under my drives. It does not show up in the device manager and although it does show up in Disk Management (and it claims to be healthy) I am not able to partition it. It gives me the error that "The request could not be preformed because of an I/O device error." whether or not I try to initialize it as MBR or GPT. My HDD is a WD 7200rpm 1TB Caviar Black. It also does not show up in the BIOS.
Not only is my SSD not up to normal speed (it is maybe faster than an HDD when loading windows but not by much) but I also can not install anything on it. It keeps giving me the error that it either can't find a Temp folder to put things in or can't create one. I had my browser set to DL things to my HDD but even though I switched it to my SSD it still fails to install as it tried to use a temp folder on my HDD.
I'd appreciate any help you guys can give...
I want my gaming RIG back =(
~LS
~LS
