clshades
lowfat could you explain the flow in your loop please. It looks really cool I just don't understand how that loop is workin exactly.
lowfat did u use municipal service tubing for that?
The Supreme HF CPU block has a similar pressure drop as the EK GTX680 blocks. Now if I were to have a more restrictive Swiftech Apogee HD instead I would more than likely run in to issues.What keeps the flow from going directly from inlet to outlet on the GPU blocks?
Here's what I'm getting at: whatever block is most restrictive will receive the least amount of flow. I suspect it's your CPU block seeing as you are hitting 60 degree temps at stock. Parallel flow only works on identical blocks.
Edit: don't get me wrong, it's a pretty loop. I just don't think it's as effective cooling as it should be. You may not care though.
What cameras do you all use ?
