Kas Nagant
New member
- Joined
- Aug 29, 2014
- Messages
- 3
I have been having this problem since yesterday. I tried to play around a little bit with memory overclocking for kicks and found I could not go past 1680, so be it. So I give it up and go back to default settings. But then for some reason I start having the problem where I cannot set the multiplier (CPU Ratio) past 34 and I had it at 46 for an overclock of 4.6Ghz before.. I tried resetting the BIOS, flashed it at least a few times to a prior version and then again to most current. I cannot think of anything else to do..
The Specs are as follows:
Intel Core i5 3570k
Asus P8P67 Motherboard
G.skill Ripjaws series 8GB Memory (4x2 kit)
Corsair CXM 600 Watt PSU
Will post more info as needed.
Intel Core i5 3570k
