Your_friendly_gamer
I just got this board on Friday last week from a good member here. I have been having lots of problems with it.
I have used 3 different sets of ram, and two different video cards a 7950 and a GTX 580, as well as cpu's. I have used a fx 8350 and a fx 6300.
The issue in the beginning was UEFI bios, i could not move my mouse and only use the keyboard. So I updated the latest bios. I downloaded the bios, put it on a usb drive FAT32 and updated the bios.
It was successful. But however the issue still persisted. The issue is, If I shut down the system or restart the computer from Windows, windows shut down, but the computer does not. All fans, lights and hard drives still spin and go. And until I either take off the power cable or press and hold the power button on the case, it will not shut down.
And when you boot it back up, everything comes on spin etc, and get the beep, but nothing on the video. Unless I then take out the power cable, clear cmos and the reboot.
Its just a lot of pain, and I cannot have the pc running 24/7 because of my 4 year old daughter.
Also, I tried to take out the ram and video card, and tried updating the bios through the ROG usb slot and urning on the ROG switch on the mobo.
Nothing helps and same issue, is there any other thing I can try, or I have to RMA it???????????
I really dont want to, as I just started at my new job last week and I use it build reports in the evening and this is my only running system at the moment.
Thanks again.
Thanks again.
