Intel Core i5-4670K, MSI GeForce GTX 770, Fractal Design Define R4 w/Window (Black Pearl) - System Build - PCPartPicker Canada
Here are my computer specs except I finally had time to disassemble and test. Replaced the PSU with a spare I had at home 600W which is more than enough.
My motherboard now does not recognize any sata ports and boots straight to EFI screen where I type exit and go to the BIOS. Tried to reset my settings. same issue.
I next tried to switch SATA ports, also no go.
I then tried to unplug SATA and let the computer run then shutoff replug in and still same issue.
I also tried unplugging the PSU holding the power button to drain all the power of the mobo and see if it would go to some default settings.
Another thing is when my computer turns on, my heatsink fans go straight to 100% because my CPU is apparently always at 100 degrees.
Anyone know what I should do next?
