Surfer_2099
Hey guys. Been a LONG while since I've posted but I need some expert help.
A bit more than a month ago, I started getting "Display driver stopped responding and has recovered" error. It is intermittent and usually happens during some games during launch (I had the Alpha of Star Citizen installed - but have since removed it, Hearthstone, Age of Conan, some Steam games - but not all). Once launched however, I rarely get the error.
It has a tendency of happening most often when I am browsing the internet and watching videos in the browser. It does not matter which browser (Chrome, IE or Edge- see below).
My GPU was a Radeon 7950 (Gigabyte) - not overclocked. Note, my display is small and only runs at 1680-1050, so it's not the most stressful resolution in the world. Sometimes I would get a recovery message, other times I'd actually get a BSOD with the error code associated to GPU issues.
I did a ton of research and troubleshot as I could.
- I tested the RAM (it's ok)
- I tested the integrity of the HD (it's ok)
- I uninstalled, driver cleaned and reinstalled various versions of Catalyst drivers (that did not work)
- I ran MSFixIt for this error (did not correct it)
- I manually edited the Registry to change the timeout for video-card (did not correct it)
- I tried the GPU in other PCIE slots (no difference)
- I tested and stress tested the CPU and RAM (all good)
- GPU temps and levels were always good and not a question of overheating
So, I concluded that it was probably a failing GPU. I ordered an R9 380 (Gigabyte) and installed it, but the "Display driver stopped responding and has recovered" message still continues intermittently.
A few weeks ago, I cleared the caches and forced the Window 10 upgrade.
Since then, it is LESS common and I never get the BSOD anymore. Just a black screen for a sec as the GPU driver restarts.
As of right now, I can usually successfully run a FurMark Benchmark and the numbers are fine.
Tonight, just before posting here, I had 4 crashed in about 5 minutes, but none since. For kicks, I ran a full FurMark STRESS TEST for a full 30 minutes with no issues.
So...
I am now at the point where I am thinking there is a significant enough issue with some of the OS files that I might have to re-install my OEM Win7 and then do the upgrade again. I really don't want to do that at all. Either that, or something is not right with some specific files somewhere and I need some suggestions as to where I should look and what I might try.
What do you guys think?
Surfer_2099
ps- I like the r9 380 so far (power draw and temps and quiet running) and if I can pinpoint the issue, I'd love to be able to reconfirm that my 7950 is still good and put it up for sale.
pps- As I was writing the above PS, I got the "Display driver stopped responding and has recovered" error. And again, just now before hitting "Submit New Thread".
So...
Surfer_2099
