enaberif
It's greyed out I'll try disabling the dchp see if it let's me do that.
You need bridged mode. If you don't it will always cause you headaches.
I'll check as for disabling they prob can't as it used to give other 2 receivers signal.
Can you clone your Asus router to the isp router? Or maybe you can use the Asus router as a access point instead? Then you get all the benefits of the Asus router speed wise and the isp router controls the dhcp.
