clshades
I'd like to see the Usb-c connectors turned or moved. Looks like crap sticking 2" straight out off the MOBO.
Placement is the issue for me. Like why is the USB3/C connector right next to the 24-pin? Why can't it be w/ the rest of the front panel connectors?I'd like to see the Usb-c connectors turned or moved. Looks like crap sticking 2" straight out off the MOBO.
Hell. Even on the back of the MOBO would be good. I don't need to see the wire at all.Placement is the issue for me. Like why is the USB3/C connector right next to the 24-pin? Why can't it be w/ the rest of the front panel connectors?
problem there is that most cable management holes won't line up for that. but that's a great idea!Hell. Even on the back of the MOBO would be good. I don't need to see the wire at all.
Heh. Right now it looks like someone threw darts to choose the design. An edge MOBO style with a 90 degree adapter would look nicer.problem there is that most cable management holes won't line up for that. but that's a great idea!
