Lysrin
Hmm. I'm not seeing that as an option in my lower right-hand (R/H) settings. You mean the pencil icon where you go to set background and shortcut behaviour?Lower R/H "settings" and then "do not show popular searches"?
Ah scratch that. You have to go manually to google.ca (as I think @Entz said) to get the setting option. If I open a new tab I get the other Google page with shortcuts, etc.Hmm. I'm not seeing that as an option in my lower right-hand (R/H) settings. You mean the pencil icon where you go to set background and shortcut behaviour?
Gone silent on this one, sorry @crazyea . Other than the browser settings and the settings in your Google account I'm not sure where to tell you to look.Well it worked briefly. Then I went to google, and disable "do not show popular searches"
and then it reappeared, but it looks a bit different now.
So dumb.
EDIT: So if I just use the google start page in chrome I no longer see these suggestions, but if I go to google.ca or .com, I do still see them. Even with "do not show popular searches" bullet checked.
think this is it give it a shoot
- go to settings.
- click on "Sync and Google services
- Disable "Autocomplete searches and URLs
you might have to turn this off to
Make searches and browsing better
Sends URLs of pages you visit to Google
its just below the others
Just get longer wires... or splice them longer etc.grr I need to buy a cheap not cheap 2.1 speaker set up none bluetooth that has decent wire length and a head phone plugin for my TV the wires for the cheap ones I have are jus ta little two short and also having issues with speakers need to wiggle the wires around so that it fully connects sometimes
