FreeKnight
I'm considering grabbing either a Synology DS220+ or Asustor AS5202T to use as a NAS and plex server. Use is mostly going to be for Plex and as a network/remote drive. I've mostly got 1080p content, but will probably start using 4K at some point. I will store some records and documents (company tax, expenses, etc) there as well but I also have those backed up on dropbox and onedrive so it's not essential that the NAS is a 'failure proof' storage. NAS will be placed right beside my network hub under the stairs so size/noise isn't a factor.
I do have a couple questions for those of you who are wiser in the ways of NAS than I;
1) I have a spare WD black PCIe 512GB SSD (older gen), I've read that some NASs can use an M2 SSD for cacheing. With that in mind is it worth looking at a NAS that supports this for my use case? It seems like no smaller ones support it and there's a significant price bump to finding one that does, so I suspect 'no' but thought I'd ask.
2) Between the two models, assuming no major price difference, the AS5202T seems like it should be slightly better performance wise and supports a higher RAM capacity (if it's even worth upgrading?). Am I correct?
3) A NAS set up for plex still works as a normal network drive/ network storage on windows correct? It's not an 'either/or' situation?
Drives that will go in there will be 1x 10TB WD 5600 RPM and 1x 14TB Exos 7200 RPM drives.
Thanks for the input gents. I'll soon be HDD free in the main rig if this thing works (which means I'll probably swap from the O11 mini back to the Ncase, but that's just how these things go )
