what are the best fans for the NH-U12s?
Marzipan
Prince Rupert, British Columbia, Canuckistan
the original, not the new variant that was just released.
I want to run dual fans and get the best temps while remaining as inaudible as possible.
there are so many 'quiet' fans out there now I get lost in the numbers (remember...dyslexia and dyscalculia).
also open to suggestions on swapping the original case fans out for something that will be quieter as well.
JD
Toronto, ON
Do you not have the Noctua fan it came with? Not really sure what's quieter than Noctua.
NF-P12 redux-1300RPM might be an option? IMO anything over 1300RPM @ 120mm is "loud" to me.
JD
Toronto, ON
Since there's no independent body that tests noise, I don't trust any manufacturer's ratings, nor do I have a SPL meter.
RPM is the easiest metric for me, regardless of whatever "fancy" blades, anything over 1000RPM is "audible" to me in the 120mm format. 1500RPM is "annoyingly loud".
