FreeKnight
Considering ditching my O11 Mini and going back to my Ncase now that I've got a NAS and don't need local HDDs. One problem I noticed was that there's a lot of cable to 'stuff' inside an M1 with the factory or the corsair braided cables. Cablemod custom is an option, but it gets expensive fast.
I know DIY custom cables are a thing, but I'm not sure how you go about getting the connectors for the PSU to cable connection. It seems like there's some variation between PSUs so it's not like I can just grab any 24 pin and be certain it'll fit into the corsair. I know there's connectors available at mainframe custom, but how do I know the connector will fit my SF750 (say this one for example; https://mainframecustom.com/shop/cable-sleeving/connectors/24pin-female-connector/)
My other option is to buy another SF cable kit and trim it to length. I'm assuming it's possible, but keeping the cable ends might be a harder job (https://www.corsair.com/ca/en/Categories/Products/Accessories-%7C-Parts/PC-Components/Power-Supplies/SF-Series™-Premium-Individually-Sleeved-PSU-Cable-Kit---Black/p/CP-8920202).
Should I just buy and try to shorten the corsair set, or is it better trying to start from scratch? I can always buy extra connector types to cover the chance that one connector won't fit in the PSU necessarily
