Go to install an custom addon for Home Assistant. Won't install. Says I need Home Assistant version 2021.12.0, which doesn't exist yet. Can't even install an older version of the addon as every single version says it needs 2021.12. So it is impossible to install the addon.
Check out the github, others have same issue. Dev says 'Then don't install it until released.' And closes the issue.
Can't install because home assistant version not released yet · Issue #1439 · alandtse/alexa_media_player
This integration depends on home assistant 2021.12, but 2021.11.5 is the most recent stable version. Error message (german): Du benutzt die Home Assistant-Version '2021.11.5', für dieses Repository...
github.com
