crazyea
Hey, I'm trying to map a network drive like I always have but the option missing. Has anyone else on the latest build of Win11 also having this issue?
You are not on the latest update. I'm on 675 with tabs, etc.
Edition Windows 11 Pro
Version 22H2
Installed on 10/1/2022
OS build 22621.675
Experience Windows Feature Experience Pack 1000.22634.1000.0
net use $letter: \\network\share /user:$username
net use U: \\unraid\media /user:crazyea
But I like to just right click. lolGood call. Updating.
As a workaround, you can use CLI steps:
Code:net use $letter: \\network\share /user:$username
Ok. So I figured it out.
If you open File explorer, select this pc, and then click on the menu, it shows up.
But If I click the quick access folders, or the network folder first, and then this pc, the menu will not show up. Weird.
