GeezerGamer
Ahhh, memories.Still need to add a few mods yet. But looks pretty good for being 12 years old.
It'd be great seeing a new Fallout game before I die
Looks good! Any chance you could share a mod list you are using, if it isn't too much work?Still need to add a few mods yet. But looks pretty good for being 12 years old.
Did you also grab the free Fallout 3 GOTY from Epic a week or two ago? If so you'll want to start w/ Tale of Two Wastlanders.Looks good! Any chance you could share a mod list you are using, if it isn't too much work?
Yes I did grab Fallout 3 I believe.Did you also grab the free Fallout 3 GOTY from Epic a week or two ago? If so you'll want to start w/ Tale of Two Wastlanders.
Install all its dependency mods afterwards.
And then these.
Heaps Replacer. Seemed to make a massive uplift in FPS. Relieves some CPU bottleneck. Went from low 60FPS to 75-115.
New Vegas Heap Replacer
This library will replace the in-game heap with a faster, more optimized version. It should decrease load times, remove some stutter and slightly improve frame rate.www.nexusmods.com
Adds settlement modding to game. Sounds like FO4 stole this idea.
RTS - Real Time Settler
Find a strategic location, start your village, establish trade routes and alliances, and fight for your freedom!www.nexusmods.com
Texture mods
EVE - Essential Visual Enhancements
New Crit Kill animation scenes, HD blood fx, HD fire fx, HD explosions, new bullet impacts, energy wep projectiles & impacts, unrivaled textures, and morewww.nexusmods.com
NMCs_Texture_Pack_For_New_Vegas
Fallout New Vegas Texture pack by NeilMc_NMC: re-textures roads, trees, landscape, vehicles buildings and interiors with high-resolution photographic based equivalent textures. Global texture replacerwww.nexusmods.com
Fallout Character Overhaul
Overhaul of characters in Fallout with new headmeshes, high resolution texture maps and a lot more.www.nexusmods.com
UI
UIO - User Interface Organizer
An NVSE-powered plugin that is designed to manage and maintain all UI/HUD extensions added to the game by various mods. Once installed, UIO will ensure UI extensions are always properly installed and,www.nexusmods.com
Other
The Someguy Series
This is the master file required for all of Someguy2000's quest mods.www.nexusmods.com
NVAC - New Vegas Anti Crash
Implements structured exception handling and sanity checking to reduce frequency of game crashes.www.nexusmods.com
NVTF - New Vegas Tick Fix
The newest generation in performance enhancement and stutter fixing. Windows 10 compatible. Featuring fixes to the dreaded micro stutter, and a high FPS Havok fix.www.nexusmods.com
I had the same ailment with SkyrimThis is making me want to play it again. I always ended up falling into the hole of spending more time modding than actually playing.
