Ah that's right, had a mix up. Maybe you mentioned one of your kids in NS, or I'm just mixing members up.Well.... I'm in NB, but I will admit that Moncton's one of those towns where they roll up damn near all of the sidewalks at dusk....![]()
But that isn't to put a wet blanket on anything you bought @Squeetard !Even if you only end up using one of those 48 inchers with your 4090 it will be a stellar gaming experience.
Been super happy with the dishwasher based on that recommendation it is in a large part why I picked LG again for this. Just really wasn't planning on this purchase yet. I planned on reconfiguring the laundry room first then putting in new appliances. Tearing down the ceiling and redoing it etc.I can definitely recommend any lg appliances. Best bang for buck
The direct drive feature in most of their products is what makes them so reliable. They are also very easy to work on imo.Been super happy with the dishwasher based on that recommendation it is in a large part why I picked LG again for this. Just really wasn't planning on this purchase yet. I planned on reconfiguring the laundry room first then putting in new appliances. Tearing down the ceiling and redoing it etc.
Big positive it has such a much larger capacity I think I can do what is normally 4-5 loads in 3. And like the dishwasher it makes a fraction of the noise compared to the old ones.
I've had a couple and loved the second a lot less than the first. Both a definitely quiet, but the handle plastic broke pretty quickly when the first one finally died (after 15-ish years).I heard Bosch is the king of appliances. Lady at work bought a Bosch dishwasher and llovesssss it. Says you can't even hear it running.
They are expensive. If you have any issues or need repairs a certified Bosch tech needs to do the work. I can't get tech support nor will they tell me what the error code issue is.I heard Bosch is the king of appliances. Lady at work bought a Bosch dishwasher and llovesssss it. Says you can't even hear it running.
