1156 Evga p55 FTW Socket Burn (Foxconn Socket)
Myst88
Active member
Montreal
Happened just today, was using an i5-750, everything was stock settings (deafult BIOS settings, had used clear CMOS). This was a second hand board, purchased roughly a year ago?
Thanks Foxconn.
Myst88
Active member
Montreal
so it killed the cpu too?
hope warranty goes tru? :)
Nope, I'm pretty much screwed. From what I can tell the seller never registered the motherboard with evga because when I call they say it's not listed, so he just flat out lied it seems. I'm waiting on an e-mail response from him. The chip was from an OEM Dell so that's no good either.
However, the chip is alive although not well. CPU-Z shows it running at just under 1200 Mhz with a bus speed of 133.0 Mhz and a 9x multiplier.
zsamz_
laval Qc
clean the cpu pads make sure none are touching
you outa luck even if you registered it
evga wont cover socket burn
glad i got a lotess sofket
_dangtx_
mtl
damn. thats not good.
remind me plz how you tell if you got one socket or the other? before you buy the board(looking up a review sample may snot mean much)
Myst88
Active member
Montreal
Why wouldn't they RMA it, that's pure bullshit. It's 100% a manufacturer error, I didn't even try to overclock.
_dangtx_
mtl
post in there forums and see what gives, maybe they'll take pity on there pubic image? :)
crazyhorsejohnny
Ottawa
That's what happens buying used sometimes. I have a buddy that gets burned (oops sorry) alot yet he keeps getting used hardware.
zsamz_
laval Qc
if they are nice they will charge $ to change the socket:whistle:
guy i knew same thing happened with his classy they charged him 100$
