1A/12W rated fan header
It varies based on motherboard spec about how much amperage a fan header can handle. I had a set of TK-123 fans that were featured by Dmitri years ago and they drew 2A each and no motherboard at the time was meant for that kind of power draw. Even today I think only pump headers if there is one on your MB is rated for something that high.
Worst case scenario there are boards that can run 8-9 fans off a single MB header but they take power from the PSU directly not from the MB.
board hooks to MB, power comes from molex, special color connection is the only one that reports fan speed. Though only 1 fan reporting speed happens with splitter cables as well.
Reguardless need to check power capacity for your specific board.
Fan is rated at 0.35A ... x3 = 1.05A... if your fan header is only rated at exactly 1A it should be withing margin of error but the initial spike of all 3 spinning up at once might be just asking for random burnt out header.
