Work in progress (2 Builds)Gaming on a Budget with Major Forum Help
Soullessone21
Calgary AB
New Tower has just started going together. (Case will be a Bitfenix Outlaw havent decided on a colour to paint it yet though)
System Specs
-1366 i7 920 (Thanks ZZLEE)
-Asus P6X58D Premium (Bought from Kijiji $50 and already getting swapped for new board with Asus RMA)(Updated swapped for new board from Asus)
-12GB Mushkin Ram DDR3 1600 3x4gb( Bought from NCIX $58 )(only new part in my build+well case is new to)
-Seasonic 740 Gold PSU (got as a gift a month ago used it for a review then it sat, now its in my new build)
-MSI 660 OC (Gift from Synapsis when I gave notice the owner and a great employee got it for me to say goodbye)
-Intel 2011 Watercooler with 1366 adapter(got two of these gave one to a awesome forum member and the other I kept thanks Intel for the toy)
-Case will be a Bitfenix Outlaw from Memxpress on friday I will update this cost($60.88 with tax and some new compound)
-Bitfenix Alchemy Cables (For a Review now for this build)
-Bunch of misc parts and DVD drive (thanks Enaberif)
-Corsair Neutron 240GB SSD(New was a gift from my old rma team I had two now I have one)
Build two is for my buddies at msi to help with bugs :)
-MSI FM2-A85XA-G65 (Got from the review circle to help with many issues it may or may not have)
-Have to pick up APU going to be K series just not sure about A8 or A10
-16GB 1866 Corsair Vengeance ram(got these awhile back dont know from where though :S)
-Bitfenix Ghost or another case if I find a cheap one that will work for my nearly fan-less design
-OCZ 120GB SSD Sata 3 (Its in my laptop now have had it for 6 months won it in a webinar)
-AMD FX Watercooler I got a few times to use them
-Onboard GPU or 6670 if I find one at a good price
-DVD Drive and PSU (thanks to Enaberif thanks buddy)
Both Systems Windows 8 Pro and all office brought to you by my old professor who now develops software with microsoft.
First system will be used for gaming and work. Second will be for media and when my wife moves her new tower as her tower now will be converted to a full time server and used to fold and host some exchange software and active directories.
Pix to follow tonight and this weekend :) I need compound to put it together haha
****Update Build 1****
So with the help of Enaberif I got the parts I needed from Memexpress and setup the system last night... and this morning couldn't find a damn screw driver so there is more thumb screws then their should be but this morning I found one and finished the build for now.
Above are the parts for the build
Above the Box
Mobo,CPU,Ram and case plus Asetek bracket all fit great
Above new card fits nice and things are coming together
Psu and cables go in kinda a mess but I have F all for tools out here
Above AIO water cooler fits really nice super snug need a better pull fan but in time or whenever I walk to the post office to get the package with them in it haha
Above still no real cable management but in time that will change
Above a new angle
Above all up and going sadly the only fans in the whole system other then gpu are on that AIO
So all up and going got it clocked to 3.8ghz on the 920 and seems to be doing great peaked at 65c during benchmarks time to get back to gaming it has been to damn long
Small Updates on the main system Thanks to
Pabz0r545 for the new fans in the system. Cant wait to Cut this case up give it a side window and mod the top to fit a 140 :)
Bond007
Nova Scotia
Nice. Wish I had the time and money (or gifts) to build new rigs. I guess when you are dealing with it all the time your are bound to get some freebies from time to time. By the sounds of what you use the second rig for I would go A8 and save the extra few $. Really either or would be fine though.
Soullessone21
Calgary AB
One system built and ready to go well still needs to get the side and front chopped up and better cable management but for now I can play games again :D
Soullessone21
Calgary AB
Thanks guys, a great forum member pointed out the obvious fact that I need to change the pump placement, I have already moved it 45% but will fix it tonight haha. Then give updated pictures
Bond007
Nova Scotia
Something I meant to mention earlier; I know your temps are good, but with your only exhaust/rad fan about mid height on the case I would really want at least one exhaust fan on the top of the case to deal with the naturally rising hot air. I know the case is well vented at the top, but I would throw a 120mm (or 2 if you can) on the top to assist the natural flow (and keep your GPU from sucking in its already heated air that is rising).
ZZLEE
KANATA
I think that CPU has a better home.
don't treat it like I did :thumb:
If you get it past 3.85 you will have beat my top clock on it.
