2 OS 1 drive
martin_metal_88
Quebec City
Hey guys, I am wondering if there is anyway possible with or without the use of a software ( i prefer to use no software BTW ) to install 2 windows on the same hard drive. Actually the issue I have is that no soft can partition my drive because all over the 640 there is some unmovable file WTH? Why Win7 put unmovable files everywhere on the disk...Now I want to install W7 RC1 ( already install ) with my brand new Win server 2008 Pro on the same disk. As I mention before I would like if possible to use no software to do it ( except partitioning software ) If I have no other choice I will use some. Please answer me fast guys.
Ask for more if needed.
DarKStar
Canada
I can vouch for diskdirector from acronis - the partition is regardless of files or unmovable files, the partition software does NOT know this since it sees sectors and the moving of sectors regardless of data.
Yes you can install more than 1 OS on the same PHYSICAL DRIVE - Tricky question - your ONE physical drive can be partitioned into several drives with their own letters and act the same way as having multi drives - you can say, install Windows XP on C, Windows Vista on D, Windows 7 on E for example
Now, from your post it seems you are using one physical drive but want to install multiple OSs on the same PARTITION.
Technically yes you can with one of the many software out there through custom bootloaders/menus.
If you install in different partitions, you need no software since the OS automatically creates a multi-boot menu - might be tricky if you install Windows XP + windows vista + a 2nd Windows XP, will lose your Vista boot - can easily be reset though no problem.
I do not recommend installing more than 1 OS per partition - While it CAN be done, you will need software like DiskDirector, which contains OS Selector, or use other tools available. OS Selector is good because it can take snapshots of your boot sectors and use those for your menus completly bypassing the XP/Vista own boot menus.
OS Selector does allow you to install multiple OSs on the same partition, in different default directories for your OS, but things can become messy in the long run, since you will be sharing your program files and other folders, it can be tricky to manually set new defaults. Conclusion save yourself some trouble and isntall 1 OS per partition after you find a way to repartition.
Make sure you backup your important data files first just in case.
whatalamesite
Member
bad idea buddy, make sure you back up important data.
i would spend the extra few $50 and get another drive to be safe.
blaster
Member
Halifax Nova Scotia
ever think of using virtualbox by sun microsystems ? Its free and lets you make a virtual pc were you can have as many different operating systems as you like. It installs like any other windows program. Allowing you to run your OS of choice within your windows program. Saves all the trouble of configuring boot loaders , partitioning , etc . Google it and see if it might be worth a try.
martin_metal_88
Quebec City
Nonono, What I was telling is that I don't know why but Acronis even windows can't do another partition because there is unmovable file. I will try some other software sugested before and hope it will work.
Ask for more.
martin_metal_88
Quebec City
Thx Jdorm17, I hope your software will work or I will be needed to by another drive. I can afford it but I want to spend my money elsewhere than my computer XD.
Ask for more
Safearus
SSM, Ontario
Well, one thing is that you could download the program prior to actually purchasing it. There is an "evaluation" version, which can be unlocked. But without purchasing the Acronis Disk Director will not make any actual changes. I'd advise testing to see if it will allow you to re-partition your drive. There is also a program I've once used called G-Parted, which is 100% free. However I don't know if it'll work in your case.
Link to sourceforge: G-Parted
Safearus
SSM, Ontario
Ask for more.
Just an FYI, Windows will protect itself in the case that you're trying to make this change from within the O/S. You should be outside of windows running this type of thing from a fresh boot VIA CD or something. Not quite sure if you are, but just a thought that I never realized until just now... LOL
