3 Digital RGB devices, only 2 MB Headers
bjcsoln
Vancouver
Question - looking for the best (or an) option to connect 3 EK devices (MB block, Res, GPU block) D-RGB ports (Addressable GEN2 LED) to my motherboard (Crosshair VIII Hero) that only has 2 digital RGB ports (and a few regular RGB ports).
Suggestions? Do I need to get a separate controller?
Thanks in advance!
bjcsoln
Vancouver
Thanks Marstg, so basically a single MB port can drive multiple devices (and I don't need some form of powered splitter)...
Supergrover
Okanagan Falls, British Columbia
Yes and no, the mobo rgb header will only supply around 60 leds (your mobo manual should say what the cap is ) after that you will want to use a powered hub/controller.
There is literally tons of different spitters , controllers out there.
I installed one of these this week and have been more than happy with it. Ton of different suppliers for this controller on ali or ebay.
I also installed one of these to my other argb header.
Truth be told the formula mod is the nicer of the 2.
