3 Mars II's
matt270avian
New member
I was wondering something today as my mind often does. In theory, you could have 3 Mars II's in a single build, right? (2 in quad SLI, 1 as a dedicated PhysX). I know this would be complete overkill, but I was wondering if that was possible if someone could do a comparison between 3 or 4 setups. The first being the 3X Mars II's, the second being 3X EVGA GTX 590's in the same setup as the Mars II's, 2X Gigabyte 6990's, and a quad card setup. The motherboard I had in mind for all of this was the Asus P9X79WS. I know this would be very difficult to do (as far as getting 3 Mars II's), but would have interesting results either way.
NightRain
Well if you ran a MARS II as dedicated Physx it would only use one of the GPU's. You'd be much better off not doing it at all, but if you had too just get a standard gtx580.
jibz
London, Ontario
I think a 580 dedicated to physx would run at 2% GPU usage under the heaviest of physx load, if used at all.
Does anybody actually play any games that use physx? I don't know anybody who does.
matt270avian
New member
I was just wondering if it would be possible on any board. I know it is complete overkill, and I will never buy it. However, it would work on an SR-2 because it has 7 x16 slots. I know it wouldn't even put any stress on the 3rd card, I just wanted to know if it could be done.
great_big_abyss
Winnipeg
so called 'bragging rights'?
If one had LOTS of disposable income, why not. The son of an Saudi Arabian Sheik comes to mind...
kazenagi
Active member
Toronto, ON
Physx is pretty much a gimmick.. only a handful of games actually "utilize" it and makes a slight difference and it'll probably be non existent in the future.
