clshades
3080s in stock at memx Calgary. Think its the north store.
That's fine and expected. Who needs food when you have a 3080 TITo add the cost of GDDRX make 20GB a non starter imho. Your basically getting into 3080 Ti price points...
Good point. Too add to this, the 3090 with more ram didn't increase performance that much. What makes one think the 3080ti will be much better?320bit memory bus width won’t allow it as your stuck with 10 chips and these seem to be always in multiple of 1GB chunks. That means 10GB or 20GB without messing with the width. Messing with the width means it’s not a 3080 anymore.
Edit: To add the cost of GDDRX make 20GB a non starter imho. Your basically getting into 3080 Ti price points...
I think it is more the what if of running into vram limits in the not too distant future on a brand new $1k GPU. Some titles already exceed 8gb (4K ray tracing, etc,etc). Having extra vram is useless...until you have insufficient.Good point. Too add to this, the 3090 with more ram didn't increase performance that much. What makes one think the 3080ti will be much better?
But by that time the 3080 likely won't be able to get smooth frame rate anyways and you will need a 5080.I think it is more the what if of running into vram limits in the not too distant future on a brand new $1k GPU. Some titles already exceed 8gb (4K ray tracing, etc,etc). Having extra vram is useless...until you have insufficient.
