3900x and Ryzen power profiles
clshades
Big White Ski Resort
This is so frustrating. I've been at it for a couple hours now and never had this issue with any previous computer. I have updated to the latest bios on my x570 gigabyte pro wifi and basically reset the bios. Only thing I changed was disabling all the possible boot options except the main drive. Change the per ccx option, and enabled XMP to max out the RAM.
I did a powercfg reset on the power profiles to remove the Ryzen power options to test so I'll need to re-install the chipset drivers to see those options again. Anyway,
I set the balanced profile to 5% min cpu up to 100% cpu but here I am in desktop idling and it's bouncing between 3.8-4.4GHZ and 1.3v to 1.4+v
My last intel board would idle at like 1ghz and barely any volts so the temps were stupid low. Why isn't this working on the Ryzen? Waste of power and just makes heat for no reason. On the old intel setup I'd just set high performance for gaming etc when needed and dump it down to balanced when cruizing the interwebs and youtube.
Any knowledge on this from someone here would be great... there's a lot to sift through on the various forum posts searching through google. What am I missing!!
Bond007
Nova Scotia
Is you cooling system spooling up at all? I have read of people having those exact issues while the monitoring software is running, and that exiting it fixed the issue (ex: on stock cooler you can hear the fan increasing in speed, and then it doesn't happen after exiting).
Edit: and as with what lowfat said, lots of things make more sense/work better with ryzen master than other programs.
clshades
So cpuz isn't showing volts and frequency properly? Hardware monitor is showing 50-60c temps and all cores live. I'll load up master though and check it all again after work.
Very annoying all the same. Short of a manual overclock it should throttle down.
lowfat
Grande Prairie, AB
It does put individual cores to sleep when not in use. But only Ryzen Master correctly displays it.
clshades
Cool thanks for pointing that out. The cores are spinning down to 800-ish with a couple at 1.2+
Cpuz is basically useless then other than getting some info on BIOS etc.
Weirdly the volts actually go lower when running Prime95 and come back up when idle.
On2wheels
613 Ontario
@clshades did you get this sorted? I'm currently testing a new windows install after many months of blue screen errors of various kinds on my Ryzen x570 system. I'm currently one bios version behind the latest, but also not running the official AMD chipset driver from amd.com,
[edit] but rather just running the default that Windows installs,
so I'm wondering if I should continue as it is and see if any blue screens appear before installing those AMD drivers.
clshades
@clshades did you get this sorted? I'm currently testing a new windows install after many months of blue screen errors of various kinds on my Ryzen x570 system. I'm currently one bios version behind the latest, but also not running the official AMD chipset driver from amd.com, so I'm wondering if I should continue as it is and see if any blue screens appear before installing those AMD drivers.
I've installed the latest chipset drivers with no issues. I've basically rolled back my previous overclock and done it through the multiplier instead. Temps are way lower and more stable. I dropped 10c from using XMP. I've had to set the ram manually as well. Running 4.3 all cores. Previously it would bounce between 4.3 and 4.8 on a couple of the cores that could overclock very high, but the voltage was bouncing off 1.5 at times and the temps were way to high imo.
So I stabilized at 4.3ghz @ 1.32v and memory is running spec 3600. f-30 bios.
