3D Printer / CNC discussion thread
danmitch1
It is the machining of the drive gears I'd be weary of.
Just curious, I could save some cash by just buying a cheap BMG for the parts but then also buy the bondtech drive gears separately no? 36$ for a coulple of gears, screws and springs seems steep?
lowfat
Grande Prairie, AB
I thought you'd be using the drive gears in that kit as well.
The Bondtech drive gears alone sell for $36 + tax / shipping at 3d printing Canada.
danmitch1
w00t ! Status: Payment being verified The supplier is processing your order
Not too shabby.. 188.28 cdn.. not the hard part... waiting!
sswilson
Moncton NB
Finished my pinball controller project. There's a spot for a joystick, but I'm only going to be using the controller for pinball and it was distracting sticking up in front of the playing field so I removed it and just replaced it with an unconnected switch.
Took 100+ hours of printing @ .2 25% gyroid infill, and it's built like a bloody tank. The case pieces alone were about 2/3 of a full roll so I'm sure there's at least a roll in it if not more.
danmitch1
Awesome! I love the dual monitors too.
sswilson
Moncton NB
Next step would be to buy some 3/4" plywood and try to make a cabinet to mount the two monitors into.... :)
sswilson
Moncton NB
I really like the effect I got with the gyroid infill on transparent filament. Gives it a textured look.
edit: Better pic of the full layout now that I've got the monitor spacing tweaked. I ultimately ended up adding the joystick back as I found out it could be used to control movement in the menus. The only button function I'm currently missing on the controller is the esc key which is only needed to exit out of an in progress game. I'll have to check to see if the steam controller settings will allow me to map one of the keys to that and have it active during gameplay.
sswilson
Moncton NB
I've got to be the worst when it comes to guesstimating how beefy I need a part to be.....
I've got a widescreen I want to mount as the backglass on the pinball setup, but the cheeparse wall mount I bought only does 100mm vesa and the monitor is 75mm.
cue this little beasty to allow me to adapt the monitor to the mount....
I want to be able to drill some washer insets into the holes for added strength so I wanted the piece printed solid, but made the mistake of setting my infill to "0" as opposed to "100" so I had to start over... when I started over I decided that I wanted a bit more meat to drill into and bumped the thickness up to 6mm from 4mm..... I suspect it'll survive the second coming once it's printed..... :)
