Hrmmmmm.......
So, using my adjusted/"calibrated xyz e-steps I've come up with a flow rate of 73.46 to give me a 2 wall thickness of .8 and decided to reset all of my e-steps (except the extruder) to defaults (80, 80, 400) and then try a XYZ cube which came out damn near perfect.
Currently heating up the bed to try another wall test at the default settings expecting that there might be a minor (very minor) adjustment required based on the changes to my e-steps (they started out as 79.5 / 79.5 / 398.something so they weren't all that far out.
If it turns out that flow rate adjustments based on a two wall calibration is all I need to dial this thing in, and extruder calibrations aren't required after each filament change, would a two wall calibration for flow be something to do after each filament change?
