3D Printer Essentials? (Or maybe better named as "Adventures in Newb 3D Printing" )
danmitch1
Yeah thats true eh, I just figured that the noctua had to be stronger and better than the stock one just cause its a noctua lol
3.0charlie
Bedford QC
10mm thk fan = clog
20 mm thk fan = no clog.
been using the 20 mm on my direct drive upgrade with no issues, same too on my previous bowden setup.
danmitch1
The noctua i ordered has 5000/4400/3700rpm speeds, I cant find specs on the stock fan but something tells me im gonna be ok.
sswilson
Moncton NB
If you're not happy with that cooler you can always try the petsfang referred to in one of those videos....
danmitch1
Ill check that out, i was going to print the one you installed but then i found the one i printed was a bit smaller. Wrong move!
