3D printing pics
lowfat
Grande Prairie, AB
You're modding your mini to do 360c nozzle / 145c bed? WTH filament needs those kinds of temps????
Those are barely the minimums of printing PEI. I want to print some of the hotend parts out of it and possible headlight stuff out of it in the future.
danmitch1
Love the enclosure, i see you use a filament dryer, does it work well? Ive been thinking of getting one.
What kind of hotend are you using to reach those temps lowfat?
lowfat
Grande Prairie, AB
It is just a cheap food dehydrator. It doesn't get used all that often. I'll print nylons directly from it and that makes a massive difference w/ PA6 nylon. I tried printing some PA12 nylon last week and it was a disaster. 8 hours in the dehydrator made zero difference, I'm going to try it again today. Otherwise I'll only use it for really old materials I rarely print.
Hotend is an E3D V6 + 50w heater + an amplified PT1000 sensor. I've used the same setup in older printers and it would top out around 375W.
sswilson
Moncton NB
Current status on my Ender 3. Biggest changes since I last posted pics would be that I'm finally rocking the bullseye now that I've got the ability to input BLTouch offsets without having to muck about with mixing my own firmware. The other change is the use of relatively heavy tiles on foam in an attempt to isolate stepper noise, but now that I've got the SKR Mini E3 w/ silent stepper drivers that's mostly moot.
Quick view of the rear. Only difference there is the addition of the two X-Axis wire guides which is intended to decouple the bowden tube from the wiring harness.
As per lowfat's recommendation, I've double nutted my bed so that it's fixed and I haven't had to look at the level in ages!
And just for S&Gs, that's what I get to see in Octoprint. :)
danmitch1
Im thinking of removing the leveling knobs all together, gain some un needed z volume ..
sswilson
Moncton NB
danmitch1
let me know if you want any custom text in what ever font.. I can send you the STL
lowfat
Grande Prairie, AB
I swear half of what I print is for device / cable management.
