3D printing pics
danmitch1
Heres a heat sink brace I designed. First time one piece hinge , so neat! Took 2 shots to get it working. A bit better than my red green zip ties i had before lol...
IMG_20201201_195233141.jpgIMG_20201201_195310255.jpgIMG_20201201_195429278.jpgIMG_20201201_195604866.jpgIMG_20201201_200316648.jpgIMG_20201201_200311184.jpg
danmitch1
Designed a new bike lamp mount. The silicone strap mount wasn't ridged enough and would move when going over bumps.
Then as you can see, the lamp is glued because I fell in the summer and it shattered. SOOO perfect time to test out some flexible filament.
I created a case for it. First time using flexible, worked great!
sswilson
Moncton NB
What kind of settings did you have to use to print the flex? You've also got a third party hot end don't you?
danmitch1
Nothing special actually. I just printed it at 210c nozzle and 80c bed . Retraction is set to 1mm and 30mm speed. I do, Im using the triangle labs dragon hotend with my custom bmg direct drive mount.
sswilson
Moncton NB
Relatively small brace post for the GPU. Seems to work as advertised and is scalable. The model has an interesting locking thread designed to prevent it from creeping due to vibration. Not completely sure if I like the copper silk print, or if I'd rather have it done in transparent PLA.
I modded the original model to include a recess on the bottom of the base in order to incorporate a magnet. (Visible in the installed closeup).
I said it was scalable, and that's a good thing.... the initial model was YUGE!!!!!! I had to scale it down to 45%.
