Please do not post any links until you have 3 posts as they will automatically be rejected to prevent SPAM. Many words are also blocked due to being used in SPAM Messages.
Thanks!
Anyone know where can i buy a 3pin to 4pin connector, not the power connector, basically i got a yate noon with 3 pin and want to connect it into the cpu fan 4 pin connection on the mobo.. Thx
If you look at the header on the motherboard you'll see that the 4'th pin is off to the side of the plastic guide. A three pin fan will work fine on that header, and a 4 pin adapter wouldn't get you the extra functionality as the fan isn't designed to take advantage of it.
