4 Ghz stable(?)
bkh2
Coquitlam, BC
http://www.sfu.ca/~bkh2/4GHZ.jpg
I am currently running at 4.0 ghz on Prime95.
Are the temps okay? I'm running a W/C Loop with just a Swiftech GTZ block and a 3x120mm rad.
BCLK: 200
Vcore: 1.3V
Everything else left on auto.
Is there any way I can go higher? The max Vcore is 1.375V (by Intel) right? I have no experience overclocking RAM. Any help on this would be appreciated.
Chris
Toronto
I am not anywhere near the experts here, but it seems that 80c is pretty high for water cooled. Also, look into the vdimm in bios and see what it says. I tried auto once, and it set vdimm to 1.79v on my board, so I now set vdimm manually.
gingerbee
Orillia, Ontario
80c is very high for water. with an ambient of 30c in my house i never go over 76 core at full load prime so my question is what's your ambient room temps. what rad do you have heat load from the i7 is quite a bit
bkh2
Coquitlam, BC
@ Gingerbee - I am also around 30C for ambient temp. I don't know why my temps are so bad =[
I am currently using Swiftech 3x120mm Rad. Also, is my voltage okay? It's not too high, is it?
@ Chris - Thanks for the heads up. I'll take a look at my vdimm in a bit.
gingerbee
Orillia, Ontario
wow you have the same rad as me too. is your block locked down all the way? ( without breaking anything that is ha ha )
other thought is it could just be the voltage your at i am only at 1.2 so if you can go lower then i would. and i never trust auto ether
bkh2
Coquitlam, BC
My ram is actually rated at 1600, not 2000.
Do I need to change DRAM, UCLK, PCIE, or QPI data rate frequencies, or is it okay to leave those on auto?
Also, what are all those other voltages for in http://www.sfu.ca/~bkh2/P8020026.JPG ?
I'll give those voltages a shot, Gingerbee. Thanks for the help.
Airshehan
Canada
If you would like your processor to have a longer life, stick to a maximum voltage of 1.3v! 80C is a little too hot in my opinion! The maximum temp for this CPU is approximately 90C. I would recommend you install some more case fans, change the waterblock if it is performing poorly and/or apply some new good quality thermal paste. If none of these bring down the temps, down clock your CPU to 3.6-3.8GHz! Good luck!
bkh2
Coquitlam, BC
@ Airshehan - Thanks! My thermal paste at the moment is Tuniq TX-2 from way back when. Should I change to The Chill Factor thermal paste? These are the only 2 that I have, excluding the one that came with the waterblock. That one just looks really ghetto...
And yes, I think you are right. I think I will reduce my frequency, since I'm not aiming for any benchmarks. I just wanted to see if I could hit 4 Ghz :D
As far as extra case fans, the case I'm using right now (Thermaltake Xaser III, oldschool :p) is not too great. It's got seven 80mm fans that don't do much, really...
