4 pin Fan headers
danmitch1
Is it safe to say that all 4 pin fan headers (from system to cpu opt)supply 12v each? I can find any detailed specs on my board (Gigabyte Aorus ultra Z390)
JD
Toronto, ON
Some will offer higher amperage for water pumps, but they're all 12V.
danmitch1
Great, thanks for confirming that! I was about to buy a splitter but realized ive got tonnes of 4 pin headers.
JD
Toronto, ON
Yup, you can plug 3pin fans into them no issue, the board should detect it as such and still be able to control the speed too.
KaptCrunch
Ontario
JD correct any 3 will fit a 4.
Another thing most are max amperage of 1amp so max 10 watt load per fan header on non pump header.
KaptCrunch
Ontario
Bring out the magnifying glass an check the smaller IC chip ID numbers off MB, To read their spec's
