4K, HDR, 10 bit, Rec 2020 display needed
lowfat
Grande Prairie, AB
You are out of luck. Such a display doesn't exist yet. The ASUS ProArt PA32U will cover like 85% of REC2020. Expect cost to be around $2500 to $2700 CAD when its out in Q3.
Jim
an hour out of Calgary
Thanks much lowfat that's very helpful ,guess we're 18 - 24 months away from seeing something reasonably priced in that specs range ?
Shadowarez
Folding Team
Arctic Canada
Been following the monitor market for decade it's rare to find a monitor that can tick all boxes ppl are asking for. It's almost as if they plant imperfections on purpose so they don't have a product last longer then nessesary.
What your asking is great but expect them to put faulty components in it if one ever materializes.
Cause tech like this wouldn't be profitable if you only had to buy 1 and it last longer then a year or 2.
From what I've seen the quality has gone down considerably and cost has sky rocketed. For proof look at cost of gsync monitors and the Quality you get. 95% rmas at one point so may end up waiting a really long time or they may come out with hologram projection before they can make a quality monitor.
