$500 Budget gaming rig - feedback appreciated
GregH
Kensington, PEI
Folks here have been super helpful in the past so thought I'd see what suggestions/improvements people had for the system I'm looking at putting together in the near future.
It'll mostly be used for gaming, and I'll see if I can do an overclock on the CPU to get it to 3.6 (possibly 4.0) as it seems that's easily doable without tweaking the voltage too much.
I have no plans to add a second video card, and I'll be sticking with my Hanns-G 19" widescreen LCD so 1440x900 is the likely resolution I'll be gaming at.
Parts will most likely be ordered via DirectCanada as the free shipping more than makes up for the slightly higher prices on some components:
*edit*
Forgot to mention I'm sticking with XP and in addition to my existing vid card & PSU I'll also be using the existing DVD/RW drive
Intel Core 2 Duo E8400 Dual Core Processor LGA775 3.0GHZ Wolfdale 1333FSB 6MB Retail $185.88
Gigabyte GA-EP35-DS3L Atx LGA775 P35 1333FSB 1PCI-E16 3PCI-E1 3PCI SATA2 Sound Gblan Motherboard $90.25
OCZ Platinum XTC REV.2 PC2-6400 2GB 2X1GB DDR2-800 CL4-4-4-15 240PIN DIMM Dual Channel Memory Kit $60.90
Seagate Barracuda 7200.10 320GB SATA2 3GB/S 7200RPM 16MB Cache Ncq Hard Drive $53.88
Antec Three Hundred Mini Tower Gaming Case 300 ATX 3X5.25 6X3.5INT No PS Front USB & Audio $52.33
Xigmatek HDT-S1283 Direct Touch 3 Heatpipe Heatsink AM2 LGA775 S754 S939 S940 W 120MM PWM Fan $31.86
OCZ Freeze Extreme Thermal Compound 3 Gram Tube $5.25
Antec TriCool 120MM DBB Case Fan 3-SPEED 1200/1600/2200RPM 25/28/30DBA 39/56/79CFM 3 & 4PINS $10.77
Silverstone Strider ST50F 500W ATX12V 24PIN Power Supply W/120MM Fan Active PFC $0 - already have it in existing machine
EVGA E-GEFORCE 8800GTX 575MHZ 768MB 1.8GHZ GDDR3 Dual DVI-I HDTV Out HDCP DIRECTX10 Video Card $0 - in existing machine
THERMALRIGHT HR-03 HEATPIPE VGA COOLER 92MM $0 - already installed on card
Total price: $515.67 including GST
I'm not 100% sure on my RAM choice - I just picked that one as it was cheap & a friend had recommended it.
Any feedback or suggestions for improvement (so long as it doesn't add too much to the cost) would be greatly appreciated!
Mibs
St. John's, NL
I've got that memory and have no complaints about it. I haven't tried oc'ing it very much though. I really don't like those Antec tri-cool fans, because all 3 I had have died on me or have gone terribly noisy. Other than that for a $500 upgrade I'd say you're going pretty good for yourself!
snoosebum
Mackenzie BC
Leclerc
Rouyn-Noranda (Qc.)
Sorry, cmetaphor is right, but I linked you to the wrong cooler. This one is the same as the Xigmatek.
Kingwin RVT-12025 Direct Touch 3 Heatpipe Heatsink AM2 LGA775 S754 S939 S940 W/ 120MM PWM Fan - DirectCanada
If it's not the same product, it have the sames specs :biggrin:. So it is the same cooler and it's a great choice. But both the Xigmatek and the Kingwin are actually "unavailable" so if you don't want to wait to much, you could take a look to the Arctic Cooling Freezer 7 Pro Arctic Cooling Freezer 7 Pro LGA775 2500RPM 45CFM - DirectCanada for around 20$ and have similar performance.
I don't really know the thermal paste, but I've heard that the Arctic Cooling MX-2 Arctic Cooling MX-2 Thermal Compound Paste NON-ELECTRICAL Conductive 4 Gram - DirectCanada was the best one. Maybe another member can help you more than me on this one.
Nice upgrade.
