5600x, x570 TUF gaming plus partially freezing
djbrad
Did you add any softwares / drivers after the win 10 install? Curious about the stability with the bare minimum.
Coach
Morden MB
I have considered that too. If it hadn't froze during a USB memtest I would be all of the OS.
Coach
Morden MB
Well my puter partially froze again just now. Could not CTL-ALT-DEL, I could use the mouse and click on some things, close somethings and others not. Could not restart the computer or power it down....
I have now swapped out the GPU. I read on some obscure site that partial freezing may have something to do with the GPU. Whatever, seems crazy, worth a try at this point
anabioz
Montreal
So funny enough, I am having something similar.
The system would randomly freeze and I can move the mouse and drag the windows that are open but the activity on it is stalled, including task manager. Basically the whole data flow freezes. Now what I have to say is this SSD was moved from an Intel system to an AMD system and since I use it for work, I really did not want to reinstall windows, but that would be best thing to do...
Specs:
HW:
Ryzen 5 3600
ASUS PRIME-B550M-A-CSM
ASUS GTX 950 2GB
Corsair MP510 960GB
OS:
Win 10 Pro 20H2
BIOS:
PRIME B550M-A BIOS 1203 (Stable, not a BETA)
1. Updated AMD AM4 AGESA V2 PI 1.1.0.0 Patch B
2. Improve system performance and stability
3. Improved DRAM compatibility
Chipset Drivers: https://www.amd.com/en/support/chipsets/amd-socket-am4/b550 -> 2.10.13.408
Coach
Morden MB
Specs:
HW:
Ryzen 5 3600
ASUS GTX 950 2GB
Corsair MP510 960GB
OS:
Win 10 Pro 20H2
BIOS:
Let me know how that turns out
ZZLEE
KANATA
If it crashes to BIOS try "Who Crashed" its a utility that's good fore understanding crash codes.
Coach
Morden MB
Funny you mentioned that. I have used that program for a long time including with my recent problems. Unfortunately it shows no issues.
ZZLEE
KANATA
If you are at default settings then maybe pull the CPU and check the pins. I was having soft crashes an some one said it was me pushing the overclock to hard fore the CPU. I dropped from 4.7 to 4.5 and have had no problems.
Pull the board out of the case and see if it still happens.
Good luck :)
