5950x build
clshades
Big White Ski Resort
Save yourself the grief. AMD loses a lot of performance as soon as you're not 1:1 with fclk. If your cpu will 'only' do 1900, run the ram at 3800.
you're better off to tighten the timings at a lower MHz then try to run the ram higher and out of sync.
Everything is synced at 1900. Should probably do a stability test.
