When new processors are launched, new motherboards are launched. It's a ritual that goes back decades now. While Broadwell-E's compatibility with the LGA2011-v3 platform means that we haven't been blessed with a new chipset, that doesn't mean there isn't anything to look forward to on the motherboard front. The second generation X99 motherboards that have recently launched represent the very best that motherboard manufacturers can create when largely unrestrained from pesky PCI-E lane limitations.
And considering the fact that there's been an almost two year gap between the first generation models and these new releases, we expect them to be even better than their predecessors...which weren't slouches in their own right.
The ASUS X99-Deluxe II motherboard that we are reviewing today is the model you buy when you want everything. It is the most feature-filled model in the company's LGA2011-v3 lineup, and with a retail price of about $420USD/$540CAD it is aimed at the higher end of the market. It is clearly a direct descendant of the original X99-Deluxe, and that's a good thing because we had nothing but praise for that model.
With five physical PCI-E x16 slots, 3-way CrossFire and 3-way SLI capabilities, one PCI-E x1 slot, one M.2 x4 connector, two U.2 connectors, one SATA Express ports, eight SATA 6Gb/s ports (plus the two on the SATAe port), three USB 3.1 Type-A ports and one USB 3.1 Type-C port many would be more than satisfied with the new X99 Deluxe II. However, ASUS didn't stop there. It also has four USB 3.0 ports, four USB 2.0/3.0 headers, two Intel-powered Gigabit LAN ports, a Thunderbolt 3.0 header, a dual-band 802.11ac Wi-Fi module with Bluetooth v4.0, Realtek's latest ten-channel HD audio controller and diagnostic LEDs. There's also thermal sensors all over, a high amperage fan header, a water pump header, and a bunch of onboard buttons and switches, and…well, you get the idea. And that is not even counting the included accessories bundles, which consists of a ThunderboltEX 3 expansion card, Hyper M.2 x4 Mini adapter, and a fan extension card with an included thermal probe.
DDR4 memory wise - which is one of the cornerstones of this platform - the Deluxe II can handle up to an incredible 128GB of RAM and it's been certified for memory speeds up to DDR4-3300. As you will see in our overclocking section, that frequency is very much within reach if you have a capable memory kit. When it comes to overclocking the processor, there are a number of excellent automatic overclocking options to choose from, and ASUS have included every BIOS option you could ever want in order to manually get the most from your components.
This unique model also features the AURA RGB LED lighting effects that were first introduced on the ASUS B150 PRO GAMING/AURA. These RGB LEDs are integrated into the chipset cooler, the PCI-E slot clips, and the audio isolation line, and they can be all controlled using the Lighting Control utility. These lights can be adjusted to any number of different colours and customized to create cool lighting effects, like pulsating with the beat of your music, cycling through all the colours, fading in and out, flash on and off, or just statically displaying one colour.
Given the fact that its predecessor was a nearly flawless product, both in terms of specs and implementation, we have very high expectations for the X99-Deluxe II. In this review, we are going to find out if ASUS have managed to once again deliver a perfectly well-rounded high-end motherboard.
