Want to Buy 750 ti or equivalent Radeon for small case
sa seba
Vancouver, BC
I am looking for a 750 ti either in low profile or just close to reference size, or an equivalent card from either red or green camp.
I was thinking of 100 CAD.
cheers
MARSTG
Montreal
GTX 750 Ti in low profile there are only 2, made by GB and MSI, you can find them on ebay, both offered by newegg and they are 170$ each and 12$ shipping. You would get a lot cheaper going regular size, but be careful as there are models that require a 6pin power connector, as the Asus version, and it will not power without it. Reference model does not have the 6pin connector.
Gigabyte GV N75TOC 2GL G Sync Support Geforce GTX 750 TI 2GB 128 BIT GDDR5 PCI E | eBay
MSI Geforce GTX 750 TI Directx 11 2 N750TI 2GD5TLP 2GB 128 BIT GDDR5 PCI Express | eBay
AMD wise the most powerful low profile is a R7 250, there are 2 models, one by XFX and one by Diamond. The XFX one has 384 Shaders, XFX R7-250A-ZLF4, the Diamond one I have seen last on sale at Bestbuy at like 80$, and it has the true 7750 chip with 512 Shaders. Diamond Radeon HD7750 1GB GDDR5 PCI-E Low Profile Video Card : Video Cards - Best Buy Canada
